High end rig with parts list! Check it out and drop a suggestion
If you are running SLI 8800 GTX's I would get an e6600 because the e6400 will bottleneck them.
I'm going to stick with the e6400 for now because I'm only running one 8800 GTX...When I do decide to run the 8800 GTX in SLI, I'm going to upgrade to a quadcore for two reasons. 1) the board supports quadcore, and 2) by the time my 8800 GTX isn't enough beef to run whatever it is I'm using, then I'll upgrade to SLI. That is when I will probably do a RAM upgrade too. 2 gigs of 1200 or 4 gigs of 800, who knows...Depends on the prices at the time. I do think I will upgrade my power supply to a 750 though because that is something I could use now, and will give me piece of mind for later when I do the later upgrade I just mentioned. So everything else looks good though?
so how much is the total for this build? w/o the 37" HD screen.
just wondering cuz i will be build my comp too and it kinda similar to yours :D
(below, in the sig)
(below, in the sig)
I inculded the current price of all components from newegg.com as of this week. Just add everything up without the LCD.
