7600GT or 7800GS
CharmPeddler
im debaiting on weather to get the XFX 7600GT with
Core clock 580MHz
PixelPipelines 12
Memory Clock 1500MHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150210
or the eVGA 7800GS with
Core clock 430MHz
PixelPipelines 16
Memory Clock 1300MHz
both agp 8x and everything else is about the same. price is close enough.
what im wondering is, does the 7800 having 16 piplines make up for the lower value in the clock andmemory speeds??
I'd probably go with the 7600GT. The cards are very close... The 7800 might be slightly better, but the 7600 requires MUCH less power and is newer.
okay.....But with more pipelines, shouldn't the core clock be higher?
It's not like a processor where you multiple the bus speed and multiplier, to come to a higher clock speed. It's similar to why the x1900 series has very high clocks, while the 7900 has much lower clocks, but performance is still the same.
You dont need to have a high clock with more pipes.
wow, i was thinking that the 7800 would beat it by just a small margin, guess i'll be getting the 7800 :D. goodthing too cause it is cheaper on newegg with the MIR atm. :D gatta love newegg!!!
ohh and thanks for the very timely and detailed responces guys, much appreciated!!
