Custom High-end Computer: Suggestions?
`PaWz
banned
I finally figured out all the hardware I need for a high-end computer, and I want to know if what I have is a good combo, what suggestions you would have to replace my current setup, or if there are any compatibility issues with any of the hardware.
http://www.newegg.com/Product/Product.asp?item=N82E16827106045 Lite-ON LH-20A1H-186 CD/DVD Drive/Burner
http://www.newegg.com/Product/Product.asp?item=N82E16811129021 Antec 900 Computer Case
http://www.newegg.com/Product/Product.asp?item=N82E16822148140 Segate Barracuda 320GB 7200RPM 16MB Cache Harddrive
http://www.newegg.com/Product/Product.asp?item=N82E16829102006 X-Fi Sound card
http://www.newegg.com/Product/Product.asp?item=N82E16817194019 Enermax Galaxy EGX1000EWL 1000 watt Power supply
http://www.newegg.com/Product/Product.asp?item=N82E16820145590 Corsair XMS2 PC 800 2X1GB RAM
http://www.newegg.com/Product/Product.asp?item=N82E16813188014 EVGA nForce 680i LT SLI motherboard
http://www.newegg.com/Product/Product.asp?item=N82E16835118223 ZALMAN CNPS9500 LED cooling fan
http://www.newegg.com/product/Product.asp?item=N82E16814130072 GeForce 8800GTX Video Card
http://www.newegg.com/product/Product.asp?item=N82E16819115011 Intel Core 2 Extreme QX6700 Quad-Core Processor
All I am really asking is if these are 100% compatible. Any help would be appreciated :)
there is no such thing as 'mid range' in quad cores yet. they are the ultimate processing machines, and they are priced to fit the bill. they are by no means to be beaten by anything else out there, so i ask you, mid-range to what? the 'higher end' quad cores? jeez.
That's what I thought. The difference between the Q6600 and the Q6700 is just the clock speed. But somebody told me the 6700 has unlocked multipliers, if so that would be the better buy for overclocking.
