Mobo to support Dual Core 2 Quads??
Is there a mobo that will support two Quad cores, Xeon or Core 2 Quad. I just thought it might be cool to build a server with.
Thanks
They have server boards on Newegg that will support two quad core processors, but the motherboards start at around a $250 price tag.
In some cases, I guess you get what you pay for. I just wanna see this action
Active just means that it uses a fan, while passive is a fanless design. I would recommend active if you have any intention to overclock.
Having dual quad-cores would also be good for stuff other then server work. Games will run well, but granted most games are only single or dual threaded at the most right now. But you would have a high 3DMark06 score :)
Gaming won't be great, and overclocking will be horrible. Server motherboards are just that--for servers. They aren't designed for gaming nor for tweaking.
