Froboy7391_99
Are there any 1333 FSB qaud cores coming out and when are they out? If there are I'm just going to get pentium D while I wait.
At least 1.2ghz will be seen for an fsb. At this time the best information sources are the reviews for getting some details until AMD lists the actual specifications? Try and find one dated in 2007! The bulk of articles and discussions go back to 2005. When they are actually out then you should be able to go direct to AMD for information on each model where they will be seen under the same and maybe additiona; catagories at http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118,00.html
Wait until Q2 in August and get that 3.0Ghz Core 2 Duo, you don't need four cores
You could just bump the FSB to 333mhz, lower the multiplier some, and change the memory divider, and you have what you want, without the wait...![]()
