microchipper
banned
obviously you cant just copy and paste your xp's C drive straight onto a slave drive whilst you are on the system in question, but... would it work if the OS hard disk was put in as a slave on another pc and transferred/copied to another drive that way??
the only problem i can predict would be the hardware change notification popping up which would require reactivating the OS within 3 days.
