wafflez
ok, I am debating between the following two cards:
EVGA 320-P2-N811-AR GeForce 8800GTS 320MB 320-bit GDDR3 PCI Express x16 HDCP Video Card $259.99 after rebate
or
MSI NX8800GTS-T2D320E-HD OC GeForce 8800GTS 320MB 320-bit GDDR3 PCI Express x16 HDCP Video Card $289.99 after rebate
1. Are these third party cards just as good as the actualy nvidia 8800 gts's, or should I find an actual ATI or NVIDIA card?
2. If the answer to the first question is yes, which one should I go for if I want to run games like half life 2 and crysis at 30fps at least without lag on high settings? Obviously bringing bang for my buck into play, is the more expensive one worth the price difference?
Ah, on a side note, regarding the comp in my sig, would I need a stronger power supply, and should I even bother waiting until june for the rumored significant quad core price drop, or should I just get the core 2 duo e6600 2.4ghz now?
or
