Kornowski
Right, So everything has arrived, CPU, MOBO, HDD, GPU and RAM.
I've put it all in the case and connected everything up.
I have the power switch and all the other case things plugged in the MOBO, I've tried putting them the other way and it still doesn't do anything?
I've plugged the 4 pin molex connector from the front of the case in, so it goes:
Case > Wire > 4 Pin Molex > PSU Molex Connector > Should there be anything after it, or is it Ok?
I'm really upset that it won't come on, If something was damaged or faulty it still should at least start up, right?
I was told and I've checked online that my PSU will work with it, It's an Antec Earthwatts 380watt.
The parts in the PC are:
E6300
Gigabyte 965P-S3
2GB Corsair XMS2 5400
XFX 7900GS XT
120GB WD SATA HDD
Antec Eathwatts 380watt
Any help would be greatly appriciated.
E6300
Gigabyte 965P-S3
XFX 7900GS XT
120GB WD SATA HDD
