Da Mail Man
how does one convert a 24 pin power supply to a 20 pin, IF that actually can be done?
If this is a 20+4 pin powersupply you don't have to plug in the four extra pins if you don't need them. But if you have one that is straight 24 pins then I don't think you can do it.
yes, the clip on the motherboard. look on the side of the connector, if its flat you wont beable to use it. if it has like a ridge to the end of it it can be separated
...thanks for the reply..i had to look more closely but damn, you are right!...i see the split so, all i just do is separate it and plug it in?
