Toshiba Satellite A105-S4274
mpsnedag
Hello people,
Thank you for your attention on this issue:
I need your help. My audio IN port caved into my LAPTOP. The head phone port is in the front of my computer, and the head phones were hooked to the computer. And the computer fell, and the Headphone port broke. Evidently, all 6 connectors snapped right off.
Do you know where I could find the same exact motherboard I have (The type of motherboard is below)? If not, then is there any way I can get the connectors so i can sauter it back together
__________________________
Mother Board:
Intel® Centrino® Duo Mobile Technology
• Intel® Core™ Duo Processor T2250
o 1.73GHz, 2MB L2, 533MHz FSB
• Chipset
o Mobile Intel® 945GM Express Chipset
• Integrated Wi-Fi® compliant wireless LAN
o Intel® PRO/Wireless 3945ABG (802.11a/b/g)
With how laptops are built into that thin frame, it's probably not worth the trouble or effort to go find the exact board or try soldering it yourself. If you really want to take this route, you should try having it repaired at a reputable shop.
The best thing for you to do is get an external sound card. PCMCIA if you have the slot.
