NZXT Apollo
dynoman
Im trying to install a front 120mm fan in the bottom but im having trouble screwing it to the case because of the front part of the case. Anyone know how to remove the front panel?
1. you have to remove both left and right side panels
2. remove the HDD bay
3. pop out the front of the case buy the black clamps you will see after removing both sides of the case
3. install it!
I had the same issue about 2 weeks ago when i built mine, i wondered how to pull it off. Just pull firmly and maybe squeeze the clams from inside and pull it out.
yeah, you have to squeeze the 6 inside clamps one at a time until you get the whole front panel off...
