Question about NEC Mobilepro 900c
magus57
If you were to put an exe file on a compact flash card, would you be able to read it on the Mobilepro 900c like on a regular computer? I want to use a SNES emulator on a 900c (which I plan to buy), because it can display at 640x240 resolution, my only question is whether it would work or not.
It all depends on how the program with the exe was written. I assume your Mobilepro 900c has Windows CE? If it does the emulator would have to be compatable with Windows CE.
