Celly
And you clarify "this celeron" Perhaps a model number on top and everything. There should be some numbers that if you simply type into google you'll get the processor model(Celeron D or whatever) and other info...
Well Ive seen some mobo's with comp ability to a celeron but they run at 533mhz and my celeron runs at 400mhz
Ill post back when I get model and do lil res
You apparently can't read my post... I shall elaborate.
Processors have models(yes, beyond just celeron and pentium...) Many also use different sockets. If I'm not mistaken the celeron used Slot1, Socket370, Socket423(I think...), Socket478, and LGA775. This is doubtful, but also some model processors are not compatible with motherboards(some of the later "server" PIII's for example)
well I knew what socket the cpu used...
478...
