I wasn't sure where to post this question. Dell has a new feature called PC tune up which costs $5 a month. Does anyone know if it is worth getting ? It does a file clean up and defrags the harddrive once a month.
not worth it if you're any type of advanced user.
What if I know very little about computers,is it worth it then ? Also, is it even necessary to do these "tune up's" ?
yeah you can do these things on your own anyways it'll cost you a lot less.
Just don't worry about it. Run your antivirus and adware scans every so often, defragment once in a long while and you should be fine.
to defragment means to run a windows utility (it's in Accessories > System Tools > Disk Defragmenter). It basically makes your hard drive run faster.
Where exactly is "accessories" located ?
