xbox 360 controller on PC??
curtains
can u use normal xbox 360 controller on PC??... i know they have special ones that are like "xbox 360 controllers for windows" and there compatiable with pc(windows) and xbox .. but what bout the normal ones .. are they intercompatiable aswell .. or is there a way to make them intercompatiable cause there like $20 cheaper
Old Xbox controllers were apparnetly a modified form of USB. So, newer ones are probably the same. If you could find the pin-out, converting one probably wouldn't be too hard. That or maybe you'd luck up and the colors would match up with a standard USB cable :P
Yes they will work. In fact Thats what I use. I wouldn't recommend the one that says it's for windows, they just charge you more for the same thing.
Do we know when the 360 controller will work for vista?
I plan to play H2V
Halo2 vista will have full support for the original xbox (wired) controller (and as far as I know the elite too). Even the auto-aim is supposed to be available to those with the controller.
the xbox 360 controllers(normal ones) are usb connection anyway arnt they? and .. whats this bout me harding that u can play 360 games on vista? is this true .. could i play gears of war? on computer?
they are usb. the 360 games on vista is a load of crap. why would people buy a 360 if the games could be played on a computer?
i would imagine the parts needed to play an xbox 360 game on a computer would be a tad bit more pricey than an actual xbox 360 which could mean more bucks for the manufacturers but Gotta go with cuffles on this one.
