Gaming RAM, is this the best bang for my buck?
Even if he can, that mother board won't support over 2gb
Huh?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188013
How can that board not support 4GB?
Anyway, that is not even the question. I am just wondering if there is better RAM for my needs. Is it worth it to buy a different brand? If so, why? Do I really need to spend the extra money for 1066mhz RAM or should 800mhz be fine (That is, can the E6600 really even take advantage of 1066mhz RAM)?
you can try this one, its cheaper and had a pretty good reviews:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145590
or if you have the budget, try this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145034
similar to the above one but with better timing
But you're not giving me any real reasoning behind those suggestions. I will either be getting really tight timings on 800mhz ram, or 5-5-5-15 or 5-5-5-12 timings on 1066mhz ram. But I want to know if 1066 is really worth it, based on my other specs. If it is, then within the 1066 variety, what is the best RAM for my buck? If 800 is good enough, then I'll obviously go for some better timings than the 1066.
I missed the 1066 MHz part... sorry about that...
IMO, 800MHz RAM would be good for gaming computer and even overclocking... some people I have seen was using 667MHz RAM without noticeable difference compared to 800MHz...
Huh?
All mother boards with 680i doesn't support over 2gb just read the reviews and you'll see it, even if it says that can support up to 8gb it doesn't really do it mostly because of the drivers.
I can't find anything that suggests that my MOBO will limit me to 2 GB of RAM.
Seems it's only with the lowest models of the mobos with chipset 680i, the A1 is fine from what i found searching thought google
