First and foremost I'd like to say hi to everyone, the names Curt and this is my first computer tech. related forum i've joined. I've done a bit of surfing the boards here and there and I'm finally ready to join the community in hopes of gaining more knowledge, so yes! i am a noob
Now I'm not a full blown noob when it comes to computers...I use them everyday doing whatever my hearts desire. I do have quite a bit of experience in CAD and a few other designing software as well as performing the routine installation of a pci, ram, etc. upgrade. I enjoying gaming (who doesn't?) and I'm always eager to learn or do something new (even if it means I get blown up with the pc
Basically I've come to ask advice and whatever other type of critisicm ya'll think would help me out a bit. About a month ago I decided it was about time to get a new pc, but instead of doing it the easy and "have-no-say" way, I want to build my own from the ground up and decide what I put in the beast.
I've pretty much used newegg as my main source, heh, my only source of online shopping for components, and I'll try to provide as much info as possible on the setup I can. So enough of the intro, lets get into the good techocobable
I'm basically looking for a build thats around the 1000 US dollar range. Mind you I do have a working lcd monitor atm, but I will be upgrading in the very very near future of this build, so thats not fully reserved in my range.
I'll go ahead and start the list of components I've been eyeballing.
Motherboard:
http://www.newegg.com/Product/Product.asp?item=N82E16813186098
Its a foxconn, and yesterday I noticed that it had a HUGE price drop (85 bucks), so I made the decision to go with this instead of the EVGA nforce 590.
RAM:
http://www.newegg.com/Product/Product.asp?item=N82E16820231098
I'm still a bit up for grabs on this, but it seems like a good snag. I'm definately wanting at least 2gigs.
CPU:
http://www.newegg.com/Product/Product.asp?item=N82E16819103778
Vid Card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130056
I know its not Directx 10, but for the price I think this is about the best I can come across atm. Plus with evga's upgrade plan, I think its a suitable decision. I do plan on utilizing sli also
PSU:
http://www.newegg.com/Product/Product.asp?item=N82E16817189014
Seems worthy enough...just wondering how it would fair when I utilize sli.
HD:
http://www.newegg.com/Product/Product.asp?item=N82E16822135106
I want two of them so I can set them up in RAID. Don't have any experience with setting a RAID up, but I'm eager to do it.
Case:
http://www.newegg.com/Product/Product.asp?item=N82E16811170022
I don't want anything too extreme, does come with two 120mm fans. I may upgrade those later.
Optical Drive:
http://www.newegg.com/Product/Product.asp?item=N82E16827129007
I don't do a lot of burning, but I feel this will suit me well for when I do.
and of coarse an OS:
http://www.newegg.com/Product/Product.asp?item=N82E16832116171
Not quite ready to upgrade to vista.
That pretty much wraps everything up minus the monitor (looking at a 19" widescreen). One big question mark I have is whether or not I should opt for a floppy drive. I'm leaning towards yes, as it may help. Any input is greatly appreciated!!
I'm going to be using this pc for normal usage (browsing web, office apps.), 3d designing, gaming, and whatnot. Anyways thanks for anything you all can offer.
Motherboard:
RAM:
CPU:
Vid Card:
PSU:
HD:
Case:
Optical Drive:
