Hi all,
Im looking for a new 120mm case fan to replace the other one on the back of my case because its over 3 years old now lol and its getting quite noisy.
What 120mm case from here would you recomend?
http://www.maplin.co.uk/search.aspx?MenuNo=54428&MenuName=Case+Cooling&worldid=-3&FromMenu=y&doy=9m5
i would like it to be quiet as possible,Yet keep the system cool.
I was thinking this one ?
http://www.maplin.co.uk/Search.aspx?criteria=A10FJ&DOY=9m5
Or
http://www.maplin.co.uk/Module.aspx?TabID=1&ModuleNo=45439&doy=9m5
However my fan i have on now can run a max speed of 2800Rpm i think so would replacing it with say a 2500Rpm or even a 1400Rpm cause any problems?
Thanks
Or
Thanks
