Some advice for when you receive the Dell.
I would unpack it and set it up and then leave it running for a good length of time with no additonal software installed on it over than whats with it. Reason being if it occures a fault from day one, you will know its nothing you have installed as if you do experience a issue, they will liekly try and say its software you have installed. Likelyness is your be all ok, just to be sure
As alot of the time its software issue if any, so at least if it runs for like a day with no other software, likely it will run okay.
Just as long as its not a dell laptop...My brother has fixed his like 5 times because the stupid charger socket always comes loose.
E1505 is great! Something must of happened to it that makes that happen.
I have a friend that has an E1505, that thing is crap. He can't stand it, he just uses it for work now, he's looking for a Macbook. If not gaming with a laptop, go Macbook.
Hmm............That's weird. I don't do any gaming though so maybe that's why I think it is so good. The only thing I use it for is working and (of course) going to CF. Of course, I would go MacBook to too.
~Jordan
I didn't mean that he used it for gaming, that would be some sucky gaming. I was just saying if you don't need a gaming laptop go with a Macbook.
