How do you partition the hard drive?
This is done when you are first installing windows, you have a screen during the setup process that enables you to split your hard drive.
Alternatively, you dont have to do it during your setup process and can use a program like Partition Magic to do it :)
Hope this helps :)
thanks man. i'll try it tomorrow when i'm not busy. i'm gonna put more ram on my comp tomorrow. you've been helpful! appreciate it bro! :)
I want to store all my media files on one. I have a Maxtor 160GB HDD.
jnskyliner34 you need to use a program that is called GParted. It's a free bootable program where you can partition the hard drive without starting over. Its a lot easier than starting over thats for sure.
Here is the download link.
http://gparted.sourceforge.net/download.php
You want the Live CD just use burning software and burn this ISO (which is the format for a bootable cd). Once you have it on a CD then boot to it. (Use VESA) VESA refers to the drivers you'll need to pick once it boots.
Hope this helps.
bullzeye2005
I want to part. my hard drive, but I am running Windows Moron Edition and all my partitions end up a preset size (something odd like 41 MB, for example), and I can only make three partitions. Suggestions?
Why are you running ME?
Suggestion: Get XP...
yup. M.E. sucks balls. i hated it. get X.P. Home at least. that's what i'm running.
Moron Edition, lol!
