patrickv
ok so im trying to connect my desktop with a laptop via crossover cable.
ok, i set manual ip range to 192.168.1.100 as laptop and .200 as desktop.
from laptop i ping desktop i get all reply.
from desktop i ping laptop i don't get anything.
Antiviruses are off and so is the firewalls.
(useless to share folder on laptop cos desktop won't see but vice versa it works)
what is causing my desktop not to get the laptop ?
(note that i tried 2 laptops but i had the same probs, so the problem is with the desktop C but where ?)
(someone once told me its taht you need to modify a registry key to fix this but i dunno which one?
