pro vs core???
striker
Is the only thing separating a 360core with a 360pro is the 20GB hard drive? If that is true then if I were to go on eBay and buy a core and separately buy a 20GB hard drive for it. Would it be the same as the 360pro?
I'm not sure but I don't think you can put any ole' harddrive into the 360. Maybe if you modded it but I'm not 100% sure on that.
So that mean yes. The only thing separating a core form a pro is the 20gb hard drive.
No, the Premium also has the chromed out disc tray and it comes with component cables, a wireless controller, and a headset for xbox live. The core console doesnt.
I'm looking at eBay not a retile store. And I don't care about the chromed disc tray.
Alright but the other three things are important:
-component cables, if you are planning on playing on an HDTV then component cables are needed
-wireless controller, its not a necessity but its definitely nice to have
-headset, if you are going to sign up for xbox live then its also a nice thing to have
