The steps to OC and AMD CPU are alittle different
Can i have a list of sofware that i could use that will tell me details about my CPU so i can monitor it?
I have had a look at the articles (wow they're huge) and come to the conclusion that im still not sure what to do, i have to go into the BIOS?
whoa.. slow down.. i'm not sure you can get it to 2.8 without a voltage increase. You may not even be able to get there at all. Try a multi of ten and a ht bus speed of 240. Then download and run prime95 for half an hour to an hour.. if it passes up it some more...
Oh and you dont need to do anything to the PSU![]()
Hmmm so raise the CPU to 2.80 Ghz and reduce the ram to 333, what do i need to do to the PSU then?
And what do you mean what do I do with my PSU?
