Two Monitors
Irishwhistle
I am interested in using two monitors with my computer and I was wondering how I should do so. Is there some sort of adapter that I need? Thanks!
~Jordan
you need a video card with two video outputs on it. like two dvi or one dvi and one vga. and if you use monitors that use VGA you can buy a converter so it goes to dvi. someone else here can show you a nice card to buy to do so.
I've got nVidea GeForce 6100 GPU and it supports multiple displays.
~Jordan
is that on the motherboard or is it a seperate card. google isnt helping...
and well if it supports dual monitors you can just plug the second monitor in and go to display properties.
