computer Help needed
chris121
Helo forum . hopeing some one can help me get some information i really need
i do graphics & web designeing visual effects and training for other stuff
i know what i want but i dont know the parts i need to get
I will like to have about 3 to 5 screens hooked up to one computer
so i can move objects around to different screens
. so now how do i go on about doing this and what parts will i need and how much will this be ( used and new)
And your welcome if you have any other tips on how i can improving my computer memory hard drive etc, computer lags really bad at times :(
holds me up from finishing work in time
Thanks to who replys:cool:
Welcome to Computer Forum! I think there is an adapter that you need to get (I'm not sure though). As far as computer speed goes, could you post up the specs of your computer? Also, how old is the computer and what operating system are you running on it?
~Jordan
~Jordan
Thanks jordan
happy to be here
computer is 4 years old
windows xp
amd athlon pross
kt266 chipset ddr atx motherboard base system
189gb memory
90gb hard drive
As far as speed goes it could definitely use a RAM uprade (assuming you meant 189MB instead of GB). What version of Athlon do you have? Try going to http://www.crucial.com/systemscanner/. It will tell you how much you can do to upgrade your PC. If you are into graphics you may want to consider a new PC though.
~Jordan
Ah sad news but will do thanks chupacabra and jordan
Its an amd athlon xp proessor 1800 + with quantispeed thats all it said
so if i do happend to buy a new pc do i look at gaming pc's
they look like they can keep up with what i do
You don't need a gmaing PC, there are other computers that are pretty good that aren't so expensive. For $820 you can get this beauty. That PC will run what you need very well. Of course, it would run even better with XP.
~Jordan
~Jordan
Thats a good deal :)
