Computer compatibility questions..
Kristy
I'm pretty familiar on how to assemble a computer, but I'm a noob on the whole computer compatibility/part selection thing. I know these questions may sound stupid, but please bear with me, I only want to learn. :)
First of all, how do you know the parts you picked out are compatible? How do you what goes with what, what doesn't go with what? What's BIOs compatibility?
How do you know what motherboard to buy/upgrade?
Is there anything else important I should know when upgrading a part for a computer?
Anything would be helpful, answers, a links.. anything. Thanks in advance. :]
- Kristy
Start here:
http://www.computerforum.com/16363-building-computers-101-a.html
Then, go to sites such as newegg.com and use the "ADVANCED SEARCH."
Start with your CPU.
Then, your motherboard; use the Advanced Search and filter out the socket. (so if u choose a c2d, the socket is lga 775)
RAM, make sure it's the right socket and speed compatibility. (check specifics on the motherboard you have choosen)
Everything else is usually on preference. Such as..
HDD. Speed, what type of connection did you want, space, etc.
PSU. Make sure it has enough power to power your whole system, and have some headroom for future possibilities.
DRIVES. Again, speed, type, capabilities, etc.
etc.
It's a very simple process, but check the link for more details and specifics.
Or if you have no clue what so ever, you can start here at the pre-choosen builds.
http://www.computerforum.com/81172-computer-specs-101-2007-04-a.html
Everything else you want to know more of can be found here:
http://www.computerforum.com/11096-ram-101-a.html
http://www.computerforum.com/11610-cd-dvd-101-a.html
http://www.computerforum.com/10947-hdd-101-a.html
http://www.computerforum.com/13239-cpu-101-a.html
http://www.computerforum.com/10764-psu-101-a.html
http://www.computerforum.com/26602-video-card-101-a.html
http://www.computerforum.com/51068-mobo-101-a.html
http://www.computerforum.com/55610-cases-101-a.html
Ok, The compatibility Part.
Ill explain only a few things as i dont have much time atm, Ill come back later for you.
When buying a Motherboard, theres a few things to consider, for example
What are you going to be doing with it,
Games
Movies
Work
School
Say you were going to use it for games,
Your obviously going to need a pretty high end PC to play the latest games,
So motherboard wise, you are going to be looking for things like
PCIE (which means You can get a card supportting the PCI-Express socket on your motherboard, The old type is AGP, Which in turn, is slower, less upgradeable options and correct me if im wrong, Cannot run in SLI Mode)
SLI (which means you can have 2 Graphics Cards)
At least 5.1 Channel audio built in (5 Speakers + a Subwoofer)
DDR/DDR2 Ram, you would never buy a Motherboard with Ram Like SDRam, Which is old/Outdated.
SATA/SATA2 (This is a type of harddrive, SATA2 Can transfer Data at 3GB/s, where as IDE is a considerably less something around 500MB/s? Correct me if im wrong on that)
The issue of Weather it will all work together comes down to knowing your motherboard, The first part of a computer you would buy would Definitly be the Motherboard, from there you can make sure all your Parts will be compatible, By following some simple things such as
If your motherboard said :
Supports AMD Athlon 64 X2 Socket 939
PCI-Express
Dual Channel DDR Ram
Gigabit Lan
8 Channel Audio
Sata2
Then you would know, That you HAVE to buy a Socket 939 CPU Chip (when you look at buying chips, they will say what socket they are)
Next, You would know you HAVE to buy a Pci-Express GPU (Graphics Card, Unless it has a Integrated Video (Onboard Video))
Next, You would Know you HAVE to get DDR Ram, the dual channel means you have have Ram basically working faster together than if you just had the two sticks of ram on a normal ram slot
Next, you would know you have a Gigabit Lan card Built on.
Next, You would know you have a 8 Channel Sound Card
And finally, you would know that Your motherboard Supports SATA2 Hard drives, IDE (standard) Harddrives will still work, But you can also purchase the Quicker SATA2 Harddrives.
If your motherboards Description says you can have a certain type of hardware, For example, the PCI-Express, then you automatically know that that type of Hardware is Supported.
I think i may of confused you, but when i get back, ill write some more Easy to understand Things for you.
Mitch
Ps, hehe that motherboard specs was stolen from my motherboards box xD hehe
2? Oops, my bad. lol.
I can't purchase that comp as of now.. (I could have, but but I got impatient and got one customized from dell) but yeah, I want to slowly upgrade my Dell XPS 410. It's not bad, it runs very smoothly, but it could be better. I'm thinking about upgrading from Dell's factory chassis, it's dull as heck.. Even though that sounds kind of shallow..
Problem is, I don't know what kind of motherboard I'm using right now.. Dell doesn't give you a choice to customize a motherboard (Are they all the same?)
Main reason i would never buy from dell...
I beleieve that they do tell you what kind of mother board somewhere in the UserManuals or whatever..
Nah, Dell always have UGLY lookin Cases...
Not shallow, Entertaining actually xD!
I Believe that shes not Buying those parts,....
Turns out it's a Dell P965 BTX motherboard.. Although I can't pull up what's compatible with it.. :\
Yeah, lol, didn't know better.. I just figured it'd be easier if I paid them to make it and ship it.. Which it was, but a pretty dumb mistake on my part. Oh well..
Is there anyway I can still add in another hard drive or upgrade my processor/ram/chassis?
http://findarticles.com/p/articles/mi_zdext/is_200210/ai_ziff32873
This article says you could.. but I'm not sure how you'd find compatible parts without the motherboard info?
Tell me what your computer actually is, not its specs, i mean like is it a Dell Dimension or A Dell Inspiron or what..
