My dad has just told me that if and when i try to spray the plastic casing of a CRT monitor the paint wont stick. Is this true and is there anything i can do to make the paint stick as i'm after a nice clean white finish. Eg coat with some sort of primer ??
However, Ive heard better results from some stuff called vinyl dye/paint. Dont even have to sand or primer and it lasts twice as long because it soaks into the plastic.
I am painting a case with 'bondo' on the plastic front panel, and sanded metal on the sides. I am sanding down the sides to get rid of the texture crap, what should I do? Should I primer the whole thing after 'bondo' and sanding?
