Twist86
g-card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130080
Proc
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115003
PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817722003
Memory (2 packs)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066 x 2
Case
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2143189&CatId=1510
Hard drive
http://www.tigerdirect.com/applicat...s.asp?EdpNo=2143105&Sku=THD-250A2#detailspecs
Few problems is I hear the 8000 series cards are power beasts will that PSU be able to handle it?
Also I can't seem to come up with a decent mother board since this is my first build.
To give you a idea I am a heavy FPS freak and this set up is for the hopes of having the power to run Crysis on the medium-high settings if not higher.
Any ideas/problems lemme know. Anything that should be changed or edited to get more power outta the rig let me know.
Also I didn't forget my drive I just plan to gut the one out of my old E-machine T6528 since I hardly ever used it.
Thanks
Proc
PSU
Memory (2 packs)
Case
Hard drive
Thanks
