Twist86
GPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130080
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115003
PSU
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1566997&CatId=1483
Memory (2 packs)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066
Case
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2337812&CatId=1842
2 120mm fans
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=1187818&body=REVIEWS
Hard drive
http://www.newegg.com/Product/Product.asp?item=N82E16822148140
Mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131142
Any ideas/problems lemme know.
Anything that should be changed or edited to get more power out of the rig let me know.
I have about $1200.00 to spend on this PC and the goal is to get as close to high settings on Crysis which looks like its going to be the best game of 2007 FPS wise.
Now I hear the prices will drop some in July so I will be making my rig then to save a bit on money and it will be 3 weeks before I have funds to buy all the parts as well.
Also I hear the CPU stock heat sink sucks should I look into another? If so what is a good one to use?
CPU
PSU
Memory (2 packs)
Case
2 120mm fans
Hard drive
Mobo
