I'm thinking of attempting to build a small hand held computer...
xenium
To play diablo 2 on.
Does anyone know of anyone who has done something like this?
It would only need maybe 16mb of video ram, 512 ram and a small 5200 drive.
I'd like it to be battery powered.
I know, I know a laptop does all of this, but I'd like it to be a bit smaller.. and hell it would give me something to work on. :)
What do you mean 'hand held'? I suppose something like a bulky laptop could be made from standard PC components, but I don't know how you could make a true handheld sized one without a computer engineering degree.
You are right.
Truth be known, I just want something to do while I take a dump. ;p
I'm sick of this gameboy color. ;p
If you're thinking of doing that, I would recommend a motherboard/CPU combo such as this: http://www.newegg.com/Product/Product.aspx?Item=N82E16813153045
It's only about 6.5" x 6.5", which is extremely small.
oooooooooooooo nice nice! but it's only 800mhz...
Single-Player PC System Requirements
* Windows® 2000*, 95, 98, or NT 4.0 Service Pack 5
* Pentium® 233 or equivalent
* 32 MB RAM
* 650 MB available hard drive space
* 4X CD-ROM drive
* DirectX™ compatible video card
hrmmmm I wonder if it could play diablo 2...
THANKS MAN!
The processor should work, but the video card is the only thing im not sure of. You may need to use a PCI card, but I dont know if that will mess up your plans or not.
Is there something similar w/ a little more cpu and/or gpu power? I can't find one, but maybe you are better at searching for these.
nm, I found TONS of them..
thanks guys! If I actually do this stupid idea, I'll post more about it later. :)
They dont have them on Newegg, but VIA has some C7 processors out which are alot better then the C3 I posted, it's too bad because I love buying from Newegg, lol.
