control internet speeds?
dynoman
I have a linksys router hooked up to my modem and three devices hooked up to my router(PC1 PC2 xbox). I was wondering if I can somehow control the download speeds of each device. Is there someway I can set a speed limit for each device?
Not that I know of, but with some Linksys routers you can set priority to each device. So if your worried about not having enough bandwidth for yourself, you can set your PC to have the highest priority.
I've found that this obviously doesnt work 100%, but it does improve my latency and download speeds when someone else on the network is downloading or uploading photos.
it gives control on a program by program basis, tho
so you could, for instance, limit gnutella traffic, while allowing internet and e-mail to remain uncapped
i agree it's overkill for a home user
i think it's more geared toward businesses, to keep people from hogging traffic for non-productivity apps, and monitor people's bandwidth usage
it would still be neat, tho. might be neat to actually figure out how to split the cable bill with my roomate each month (altough if that was the case, ID be paying for 99% of it :()
So does QoS. You can give your bit torrent client carte blanch if you want to, or limit it, and you can even set times of the day where the limits change. Like let bittorrent eat all bandwidth from 3 am to 7 am every day.
so does QoS
There are many ways to accomplish this, setting up a proxy server with authentication (squid proxy) and then limiting each user a cap on bandwidth....problem solved.
The problem is, that a lot of home consumer routers don't have the robust QoS, so you may have to look into third party firmware like from www.dd-wrt.com
