You are a Victim of Software Counterfeit??
Status
Not open for further replies.
i.mehrzad
OK let me be frank. I use a pirated copy of Windows XP(Professional).
Everytime I switch on the computer alongside the Welcome Screen there is always a Message indicating that I do not have a copy of Genuine Windows.:confused:
Well what on Earth must I do in order to avoid this message from coming. I know that i do have a pirated copy and do not want to be told about it (by Windows).
Well they are gonna lock this post since you said "I use stolen stuff"
There are cracks that can stop this process....but its best to buy a legal version of windows to prevent these problems.
Yes, that message will appear when you install pirated version of Windows and you turn on Automatic Windows Update. My suggestions can be: (1) Get genuine Windows software or (2) turn off the automatic update. However, if you turn off the automatic update, which contain Windows Security Update too, it will be harmful to your system moreover when your computer is online. Thus, the best thing is get the genuine version IMO ;)
go buy an OEM copy of windows xp
wait you're from india? Dude, just call tech support it should be a local number for you
HAHAHA thats classic tlarkin... I agree you are a moron just go buy windows its not that expensive and if you cannot afford it go apply for a job with dell i'm sure they will gladly hire you for $10 a week to help us "stupid unknowing" americans as dell said once in a documented report lol. Maybe you will get lucky and they will give you a pc! IDIOT!
and I also hope you die.
Kent.
WTH...whats up with you :confused:
Yeah i would just buy another copy of Xp or even Vista home premium if your system can handle it depending on how much you have to spend :)
Thats all i can think of.
Status
