Setting ram timings....
ThatGuy16
My corsair memory is advertised as 5-5-5-12 @1.9v, its set default on my motherboard at 5-5-5-18 @1.9v....i read reviews that people set it to 4-4-4-12 @2.1v....now in bios do i just set the memory timings to 4-4-4-12 and in voltages set the memory to 2.1v? is that all i need to do? Thanks.....or should i just leave it alone and not risk it? :P
The timings aren't that important. Even if you lowered them considerably you probably wouldn't notice the difference.
probably only in benchmarking software or intesive program use, but general usage you wont be able to tell the difference.
Yeah, i changed it to 5-5-5-12 @1.9v as advertised...ill just leave it alone, i may in the future set it to 4-4-4-12. But it would be fine for now, still gotta get XP :mad: then i can have fun :D :rolleyes:
