That's why GParted live for cd comes in handy at times. When going to create a driver floppy first boot with the Asus software disk and use the option to format the floppy there. Once done load the disk on another system to use the create sata driver disk option while in Windows. This will insure that the XP installer is able to load all of the drivers needed.
Simply downloading and slapping the drivers on a floppy won't work. For some reason the way the Asus board disk formats the floppy is fussy there. But it works over simply throwing the drivers on. Once made up boot off of the XP cd and you can choose between deletion of the current or saving time by trying a repair install of Windows to get things running again. http://www.michaelstevenstech.com/XPrepairinstall.htm
Well for one thing he has a Nforce 4 chipset so he should not need a floppy, so there another problem going on. Second I have installed all kinds of Asus boards and just putting them on a floppy has (allways) worked if I needed to install them. You must a have (alot) of crap hardware or a bad user. And I am sure you can give me a bunch of examples of how it didnt work for (YOU)
Well that first sentence didnt make any sense? But you really dont know what chipset sata drivers are on XP do you! Theres just a few chipsets that even need Sata drivers for even Windows 2000 much less XP. I can tell you havent done nowhere near as much computer work as you claimed you have. Now am I talking with PCeye or one of the other ones that fill in!
To you alone that won't make sense. But if you read further...
At this point the need to determine if anything more then a repair install is actually needed to see Windows running normally rather then rushing to reformat the drive. Even for a fresh copy of Windowss to go on you generally don't wipe the drive entirely unless you know there's some type of virus running rampant on it. A little more information on the actual error seen would help even more. You may not even need a repair install.
