CPU temp monitoring
cquence
I have a case that has temperature monitoring. Now do I leave the thermometer on the CPU under the heatsink? And what temp is safe under full load?
You dont put the thermometer under the heatsink, put it on the heatsink somewhere if you really need it. There are plenty of Windows apps that will monitor CPU temps.
What program is good and where can I download or buy it? Which one is more accurate? The software or the case temp?
