INTELCRAZY
banned
A little help with this, plz. I need to know what partitions to make, I am using VirtualBox and I have set aside 16Gb.
Thanks
Thanks
no virtual machines use virtual hard drives. I am not sure exactly how virtual box works because I don't use it, but what you want to do is set up a dynamic virtual disk, like for 5 gigs or something and then install the vm through their installer with the ISO of the linux distro you want to run. If the virtual machine gets bigger it will grow in size since its dynamic. If virtual box doesn't support dynamic virtual disks then just make one for like 10 gigs or something.
I am sure virtual box has tutorials on their web page.
I think I have it, I used /, /home, and swap. I read on some forum's guide, it said that is all that is needed.
yup looks correct
/ is the same thing as root
and swap doesn't have to be seen as /swap because you'll never actually access that volume, only the OS and kernel will.
