I have it maxed out, and I get a constant 60fps (capped). I dont watch the framerates constantly, but I havent seen it go under 60.How does that play for you OMEGA?
I get a little lag while jumping...
And how do I get fraps to work lol
It deffinitely isnt as good as I thought, it looks pretty much the same as Halo 2 on the 360. But what do you expect for a game desiged for the original XBox?Why does it look so bad, I expected it to look a lot better.
You should expect it to dip to around 50fps or so when theres an explosion, but as long as it doesnt dip to around 30 or lower, you should be fine anyways.If I upgrade to 2gb ram, oc my cpu and gpu while on stock fans.
Will I notice no more lag and better graphics?
Thanks.
hay, do a video with fraps!
