Finaly Found A Cool Case!
Finaly Found A Cool Case What Do U Think??
Hello :)
up until now i have had a heap of trouble trying to find a good case with similar design to the new alienware case, however i have finaly found one and just wanted to post a pic of it so if any other people are looking for a case with a sleek and interesting look u might want to consider this one :)
http://www.raidmax.com/specs/rx9gt.htm
i think it looks sexy as!
ALSO if u REALLY want something similar to the alienware case raidmax also make one called the ninja.. however i think it looks a bit boring...
http://www.raidmax.com/specs/ninja.htm
if anyone else finds some pics of some cool sleek cases please post!
but please dont say the p180 or 900 im sick of hearing about them besides the P180 looks like a refrigerator unless u get the mirror finished one which looks sweet! i recomend the mirror finish p180 for paris hilton :P
They look like a pile of gash i think - blue and red dont go together . What is an 80mm fan going to do to a high end system aswell?
i supose colour and outer design is personal prefrence, if u read the specs it says theres a 120 fan in the front to bring in the air and a rear 120 for the purpose of exhaust, the only problems i have read about this case is there is alot of electrical cables inside which is easily fixed with som ties, and apparently the aluminium case is thin which doesnt bother me cuz i wont be throwing it around too much :D
Blow air on it or away from it? That is what fans are designed to do afterall
Yes but a tiny fan blowing a bit of air into a big case isnt going to cool anything i wouldnt have thought, considering you can get a case with a 36cm fan on the side which would be significant
Blue and red dont go together? So the American Flag is a 250+ year old fashion disaster?:D Just messin. However the two cases do not apeal to me. If I had to pick one of the two I'd go with the second one, I like the white look better.
I don't like those alien looking cases or ones that look like cars, I would rather have something that is clean looking. Those performance cases are all cheap, and not very sturdy.
the small side mounted fan isnt to directly cool the internals its to promote air circulation, its the front and back fans that pull and push the air through the machine so therfore theres a constant flow of fresh air passing through it. i suppose they should have made a grill on the door so atleast that way the panel mounted fan could also bring in new air while also circulating... but meh u cant get everything
Where as you can get a large roomy case with a huge side panel fan that blows onto the motherboard and components and hellps reduce temps.
yeah very true would be great to have a huge side panel fan but both side panels on this case r see through so anything bigger will protrude out over the clear panels... i think the fans it comes with will be sufficient for what i need i wont be using double graphic cards or anything im getting a single 8800GTX which has its own fan anyway so it should be fine
the second one, i hate the eyes, too garish. theres lots of cases that have those things on the front but for me no case will ever come close to the alienware P2 chassis :P
hnmm :( ur soo lucky i want the green one. alienware are definately the sleekest up to date looking computers, in my opinion anyway
