How long can you last?
what the ****
i can only get 20 and that after about 40 goes on the thing
I got up to over two minutes on my old computer, just because it was so clogged up with crap and was all around slow, all the blocks moved in slow motion, so I was set, lol.
Can only do 30 with a decent comp now.
i got 144 seconds
And i swear to god i did not photoshop/edit it. There is an easy way to beat the game anyone care to know it??????
i got 144 seconds
Multi-task much?
I figured there was; some sort of simple, algorithmic moves or something.......
*ROFLES* Find: ****
Lmao. I didn't notice the find: but i was absolutely sure those scribbled out tabs were either the sites you went to "cheat" or Porn.
Is there a blind spot?
oh dear, that was when i was creating the swearing thread, i did a search on certain words and was trying to find them in the threads. Thought i would quote some examples but then thought better.
Cant believe i didnt spot that !!!!!
i find that ctrl + U creates a great blind spot
the boxes seem to move the same path each time. so once you learn there overall movement pattern via trying over and over, its not that hard. each time you'll get farther and farther. that is, if you can remember where the boxes are going to move :P
I haven't played this in a long time but I seem to remember only needing to move a little left and right. I believe there would be a safe spot if the black outline wasn't there.
there is a safe spot in the top left hand corner for the first 10 seconds and from then it starts to spped up and you got to try your best
