Just reformatted, need internet help
Altec88
As the title says, I reformatted and the net says limited or no connectivity....I installed some drivers for the network card from a dell disc, and ideas?
Sounds like the driver's installed but it's just not picking up an IP or anything... what type of network/internet are you running? Do you have a router or directly connected to a modem?
Charter 3meg cable internet, going from modem straight to computer, no router. Internet worked before reformat.
click start
then run
type cmd
click ok or enter
type ipconfig/release
>>wait a minute
type ipconfig/renew
/// also in the run box
type sysdm.cpl
enter or ok
hardware tab
then device manager
do you see any " X" or " ! "
or uninstalled devices, specifically see if your network card is in devices
go back to the first step
type ipconfig/all
post your ip and gateway address
...if you have cable turn off the cable modem, and the pc, turn the cable modem on wait for it to train, then turn on your pc.
after you get this issue fixed you really need a router or a firewall to protect you from the internet,,, a router is best and they are cheap.
