Wireless PCI card and Vista x64
ThatGuy16
Arrhh...
I just got vista x64 installed and i have a PCI Linksys Wireless-G adapter and i cant get connected to the Internet because it doesn't have the correct drivers, of course i go to their site and the have 32bit drivers but the 64bit drives are to be determined for release date!
Any suggestions?
This on a desktop, cant you run some ethernet cable to ya PC for now till they fix the driver issue... unless u wanna buy a new PCI card for ur PC?
Yeah, my new one i just built i was going to keep in my room but for now i brought it down to the modem/router...know of any pci card that work with x64 vista?
nope been there just wonderin this is a desktop right y do you have 64 bit OS instead of 32???
i have a linksys wireless g pci adapter and you just have to run the setup compatibility in xp but if it wont work on 64 bit then your kinda screwed right now they dont have any out right now that are by themselves compatible with vista
