Pc_Pimp
What is a good 22" widescreen LCD monitor to get? I found this one the SAMSUNG 226BW Black 22" 2 ms (GTG) DVI Widescreen LCD Monitor 300 cd/m2 1000:1(DC 3000:1) but are there any thats better for the price.
What do you mean its not a true 2ms anyways?that is not a true 2ms anyways
The LCD i posted from Dell has a response time of 5ms...Is that the only bad thing about Dell LCD's? They look good to me but i dont know. What do you consider a good contrast ratio?Dell LCDs are alright, but the response times arent the greatest. Pretty much do this- as long as it isnt a Westinghouse, has a response time better than 5ms, and has a good contrast ratio, get it.
Dell's are too expensive. 5ms is a good response time. A good contrast ratio in this case would probably 1000:1 or so.
Well the Dell i was looking at is cheaper then the Samsung i posted above.
Well thats the first time i've heard that but i'll have to stay away from it then. Got any more suggestions anyone?be careful with that samsung, there are three versions of it out. every review i have been able to find says 2/3 are terrible and 1/3 is amazing. do some research before you buy it
