Takes a day to power up?
OK I can see the power light on the motherboard...
In a few hours 4 -12 it will be as if I just pressed the power button and everything will start spinning and humming and so forth and it will boot as normal. I just don't understand the lag between pressing the power button and the power actually coming on...
I am thinking PSU? upgrade to a ANTEC PSU/TruePower Quattro 850W? I mean i haven't mentioned I run 3 drive caddies so I can swap out hard drives easily (I use it for Video, 3 D and Gaming)
Do you have everything plugged in correctly, the 20 and the 4 pin connector to the motherboard, are they in?
That power supply should have no problems... It has a good amount of Amps on the 12v Rail.
Yes, all the cables are in... it seems as if it is having to charge for ages before having enough juice to power up - completely stumped
make sure you turn off any external hard drives. sometimes computers think the operating system is on the external and not the internal.
