atomheartmother
I recently bought a video card from them, and it turns out that it's for whatever reason not compatible with my computer. I figured this wouldn't be a problem as I could just return it.
WRONG! Apparently this item is non-returnable. However, NOWHERE does it say this, unless I check "Returns Availabilty", where it says "Returns NOT accepted".
How in the heck was I supposed to know this prior to purchasing it? It's not listed ANYWHERE. In fact, NO item is listed as returnable or not returnable. Tiger Direct just simply states that some items are returnable while others are not. How was I supposed to know whether or not my item was returnable? Was I supposed to call? Should I now call EVERY store I wish to buy something from prior to purchase just to make sure that the item is returnable.
I just don't get it. Why can't they list the return availability in every item description? This is the ONLY store I've come across that doesn't do this. It's like they're purposely setting it up to screw over customers. How in the heck do they get return customers?
The ironic part is that despite this being a store that sells high tech equipment, their website (specifically the return system) is so poorly implemented. For whatever reason, I was issued an RMA number stating that the item was incompatible. However, only after did I find out that returns aren't accepted. It's funny; it says "Status: Authorized for return", but two spaces over, it says "Returns NOT Accepted". So which is it?
Needless to say, I'll NEVER be shopping with them again. I'm now stuck with a useless video card. Although it was cheap, it's $37 I'll never see again.
Here's the stinking item:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2974653&body=MAIN
