Will this PSU fit?
gta_140
I've never replaced a PSU before. That said, how do I know if the CORSAIR PSU I want to get from Newegg.com will fit in my HP a1467c computer? Do I just get the physical dimensions of the PSU and measure the space available in my CPU or is there somewhere I could find the answer?
in those cases you might have to remove your heatsink from the cpu and install it, if you do that i would get some new thermal paste
I dont have another computer, and since I'm buying the PSU online, I cant check and see. I just dont want to order it and when it comes in, realize it doesnt fit
it should fit, but like i said you may have to remove your heatsink from your cpu
I have an old compaq presario that had an power supply that was not standard. Usually on newegg or other computer part websites it will mention the dimensions of the power supply. Get a standard psu's dimensions and compare.
