650w enough?
that unit is grossly over priced for what you are getting !!
for about $10.00 more you could get the Corsair HX620 which in comparison will blow the doors off that Coolermaster which is only 70% efficient compared to 85% Corsair
The Power Factor Correction is only "passive" on the Coolermaster and its Active PFC on the Corsair
the Corsair is rated for operating case temps of 50C >>>> the coolermaster is a 25C temp rated unit :eek:
The Coolermaster has one year warranty >>>> the Corsair is 3years or 5 years dont remember exactly
in summary; the Corsair is the far better "value" the Coolermaster is way over priced for what you are getting :rolleyes:
Also; the Antec Trio Power 650 watt is cheaper than the Coolermaster for about $125.00 and has the same specs as the Corsair
If you haven't notice he lives in australia so those 135$ are $AU no $US
