How much of a difference is there in gaming perfromance between the 8800GTS 320mb, 8800GTS 640mb and the 8800GTX? Any charts that compare the three?
So if i wanted to run at 1680 x 1050 resolution i should probably atleast get the 640mb version of the 8800GTS?In basic terms, the 640mb GTS performs a lot better than a 320mb GTS at higher resolutions. But hardly noticable at say 1280 x 1024.
Whereas the GTX out performs them all by quite a way, at any resolution.
If you want to play maxed out at those resolutions, I would recommend it. You could probably get away with the 320MB at 1680x1050, but you may start to notice some lag.So if i wanted to run at 1680 x 1050 resolution i should probably atleast get the 640mb version of the 8800GTS?
Ok thinks guys i think after i get some money saved up over the summer i'll get the 8800GTS 640mb depends though i have to pay for my car insurance and gas so i might not get much money saved up![]()
Ok let me know after you get it tested out how it performs if it maxes out settings without lag or not? Plus i'll be running at 1680 x 1050 resolution so that will probably make a difference.Just get the 320 MB version that should perform fine but I will know tomorrow when my pc parts come.
Ohh all right well let me know how it goes.Ya I have a 20'' widescreen so I will be running 1680x1050 on all my games if I can.
Umm well really i dont have many right now so i plan on getting some new ones shortly so just any good ones ecspecially First Person Shooters.Ok what games do you want to know about?
here's something. when i played quake 4 on ultra settings it warns me that it will require 500MB for texture memory on the graphics card.
