I've never had my computer completely freeze when I ran out of RAM. Typically the program I'm running will lock up and I can simply CTRL-ALT-DEL out of it. Most of the time I have some warning before anything too bad happens...As in I've never lost anything due to this![]()
where do u disable or lower your swap file usage?
erm...Max ram? don't you mean minimum or recommended ram?you should check PC games max ram specs, the latest pc games so far i guess requires a max of 2gb ram.
You could but your video card also has to process those big textures, don't think that if you get 8GB of RAM you can put massive textures in and expect it to run smooth unless your video card can handle it.more memory also means that you can mod your games with LARGER textures to have greater detail and visual appearance.
, windows seems like the logical place though) that said "catastrophic failure" it was funny in a geeky kind of way![]()
I was thinking of upgrading and buying a 2GB ram kit to go along with my 1GB kit of 2x512mb but is 3GB of ram really needed for anything or would it just basically be a waste of money?
