OCZ Reaper - Opinions?
Sounds and looks good. Ocz makes quality products so I would assume it's good.
This is the first time seeing those btw
They're okay, but to use them most of the times you have to up the voltage to like 2.5 or 2.6 which isn't a good thing
What do you mean by "to use them?" They just wont work unless you up the voltage or you wont get those timings unless you up the voltage?
hi , i have the reaper ram. and its great. Im running it at 1066mhz at 2.1v ive had it at even less volts then that. No need to run it high. Awesome RAM....................... looks good too.
