Looking for a serious gaming comp!
I am looking to buy a serious gaming laptop. I need some suggestions as what to get. There are so many choices and I am having trouble deciding. Here are my requirements:
-Must be from www.newegg.com so I can buy it on credit on my newegg account.
- Must have at least 2 GB of RAM.
- Must have at least 100 GB HD. Preferably more.
- Preference towards a 512 MB GPU.
- Great preference towards a tablet PC.
- Preference towards 64 bit Vista installed.
- Preference towards a laptop that can be overclocked.
-$2,000 budget.
http://www.newegg.com/Product/Product.aspx?Item=N82E16834117539
- Preference towards 64 bit Vista installed. <---- i have not seen one in newegg that comes in 64
- Preference towards a laptop that can be overclocked. <------ i dont think so.
http://www.newegg.com/Product/Product.aspx?Item=N82E16834220182
Why cant it be OC'ed? I know laptops cant be OC'ed like a desktop but cant they still be OC'ed alittle? If it does not come with 64x Vista do you know which versions of Vista are 64 bit versions? i.e. Ultimate, exc.
OCing a laptop = bad, I know since my laptop is OCable. With no way to improve the cooling once you OC, it will heat up tremendously faster than a desktop (less air space + no way to put in extra fans). Just a bad idea to OC a laptop.
-$2,000 budget.
You're not gonna find a tablet gaming PC. You can go with either a tablet or a gaming system, but likely not both.
